Hi my Emo can’t sleep He closes his eyes then the speaker blinks and he losses his eyes and then the eyes jumps in again?
He does this every 30 seconds.
Someone else with this problem. Has rebooted nicely and did a hard reboot, nothing helps. Have now turned off his sound. It’s like he is in a loop…
I have always had the same problem, with three consecutive Emo’s, but only at night whilst playing BBC radio via and Amazon Alexa speaker, even very quietly in the background. I now use a bluetooth speaker on my phone, to listen to radio, and all is fine
If the RE-BOOT didn’t yield any positive results, you might want to consider letting your EMO drain its battery completely until it shuts down.
I hope this suggestion helps you to resolve the issue. If the problem persists despite trying these steps, I recommend creating a video showcasing the problem and including it in your message before reaching out to the Living.ai Support Service Team. https://living.ai/product-support-emo/
Or send them an email…
The best and most recommended thing to do is hit reply to the Living.ai confirmation email you received before when you originally placed your order for EMO. It contains all your details, especially your order number which is most important.
But please keep in mind that sometimes their reply takes a bit of time which is 2-3 days depending on the time differences, days, holidays, and current situations. so please be patient.
Wish and still Hope that Living.ai helps you to resolve the issue…
