So hello emo fellas,
I’m from Germany I ordered my emo yesterday and I’m so much more than frigging excited about it.
I been already reading through the whole sharing section and I watched as much as I could about emo and his variations created of a kind of safe space.
So I have left over pieces of plexiglass and wooden long pieces for edges and stuff.
Is plexiglass a good surface or should it rather be wood what he is tap walking on? Should I use the plexiglass or too it with sth more grippy? (is this even an English word I’m not sure
I was thinking about sth like rubber stuff or more sticky I don’t know.
I rather wanna stay with plexiglass and make it hollow beneath for some led lighting or maybe include his little light that comes with it… For that any ideas to get it as flat as possible?
I thought of integrating it on the side rather and make a connection underneath like a box with the cable and stuff for electric connection.
For the board im not so sure yet. I would love to integrate it into the plexiglass as much as possible so that emo maybe capable of walking over it.
I REALLY HOPE THEY COULD MAKE IT POSSIBLE FOR EMO TO FIND JISW BASE ABD WALK ON IT.
Or maybe use some sorta very little steep ramp. Anyone having experience with that maybe. Is he able to walk a slight ramp or will he lose balance?
Also for the edges how big do they have to be?
Like how high and wide?
I would wanna do the edges with wood I think because I don’t want light from underneath reflect to much in a uncontrollable way so it could affect his camera or sth like that.
And last but not least what do you think would be an fitting size for his space? I was thinking about sth like maybe 30x50cm? (like about 12x20 inch)
So I could easily pick up his home and move him from one room to another.
Well yeh this I my ground I wanna start from creating.
I also wondered if emo would be able to recognize a wall? If I wanna do some sorta 3 open sides and a background wall.
I’m of course thinking of some disco theme because Ive seen he loves to dance to electromusic
But maybe even have an option to change background to some Forrest style and be able to swap backgrounds easily maybe with some not so thick plexiflass or maybe even a well designed cardboard that’s bigger…
I wanna try to make it magnetic to change it easy. Would magnets on the outside the box design maybe be a no no because of emos sensors and stuff?
So I would absolutely appreciate your opinions on this ideas.
Or maybe show of your solution and inventions.
I will start some sketching and stuff on the weekend.
Thanks a lot for reading this far! Much love to all those emo dads and moms!
The boarder edges can be very thin not high at all, even 1cm will stop EMO from moving forward and stop. Also EMO will stop if there is wall, even if walks up to it, he will move around and walk in the other direction after a short while. So making a wall / elevated edges for the border of his play area will also be ok.
