Emo legs make mechanical sound while moving
Hello, @bohaoliu . . . if it is concerning to you but you cannot get video that can capture the sound, I would still contact service@living.ai with your EMO I.D., order number if you still have it and a description of what you are hearing and ask them if they need to look into it.
Otherwise, I would not worry about it and perhaps over time if it is what you said, it could possibly work itself out to where both legs will sound the same.
Hi linda
Still thank you for the advice
I was talking that newer phones cameras make sounds identical so i video i worry about misunderstood but still in the services let me think about it
To make things clear:i meant that the issue isnt related to emo feet,dirt,draggings or im talking about defect
The servos on the first day both are torally silent,until lots of use then i head that only one servo hears louder than the other,the other still hears a bit silent
So question is,is it normal? Because emo walks normally and perfectly without a issue,can be fixed or anything you can give me
Thank you
Hello, @bohaoliu . . . I personally would not worry about it, but like I said, if it bothers you, service@living.ai is who would have to advise you on how or if it needs to be fixed. I cannot tell you that.
Hi linda
At least helps but since is a new replaced emo im just more cautious
But service now is taking long so i ask you if you know about it
Because i also hear like micro cracks on emo servos as i talked before and one aound more than the other im alarmed
Dont misunderstand this
Hello, @bohaoliu . . . if there are more concerning symptoms (not ones I have experienced with micro crack sounds), then you will have to contact service@living.ai like I said above. I realize it takes time for them to review and respond, but they are the only ones who can properly diagnose and advise you.
