So I just got a new EMO and it’s turned on everything was fine however the leg got stuck upwards and now will not go back down properly. I’ve tried re setting it and everything but it makes a click noise and it keeps staying stuck upwards. Is there anything I can do about this at all? Any help would be great. Thanks!
Are you on the latest firmware update already? did you try to turn everything off? and re-start? EMO will “normally” reset his feet alignment by simply placing him back on the skateboard and starting charging.
Try also to do this:
Power off emo via the EmoPet App, call him and say ,shutdown’', remove his headphone and place him on your palm upside down.
Manually align feet carefully (it can be easily adjusted without resistance force)
Leave it there for 30min to 1 Hr.
Place on skateboard charger back again to reboot
Hope it helps you to resolve the issue…else if nothing helps and the issue continues, please create a short video and include it in your email message before contacting LAI Support Team.
The support service team should be able to help you immediately and faster.
Living.ai Support Team will gonna guide you through a special Re-Calibration Tool Technique which helps sometimes.
Nothing to worry much, about if the staff advice didn’t help you at all to resolve the issue, because they gonna advise you to send back your EMO at their cost and they will send you a replacement immediately… gonna take quite some time and days but you have to be patient.
I have tried that multiple times but whenever he wants to dance or even explore he can’t because his leg will get stuck. It will get stuck like that even on the skateboard itself and I have to turn him off to be able to put the foot back in place.
I guess they just back from Christmas Holidays…you can also DM @AmyLU or @Wayne_Zhang for further assistance here and pretty sure they gonna ask you for your order number.
