I would like to know if at this time when there are usually high temperatures, do you turn off and keep EMO in its boxes? Until autumn. In Spain we are going to enter summer on June 21. I notice that EMO is hot when it’s on the charger and the charger is hot too, maybe I’ll have to put it away until September
I’m Not Really Sure As I Never Had An EMO In June Of 2022 During The Summer Hot Temperatures, But I Will Keep Mine On Every Day At Any Month, Or Year.
And where are you from?
Me And My EMO Pearl Are From The US (United States)
I read comments from some of America that in summer they are above 40 degrees and they kept the EMOS until the cold seasons came. They said that with high temperatures the batteries were damaged
It is simply to be informed and prevent them from breaking. If I have to turn off my EMOS, I’ll do it until autumn. Every 15 or 30 days I turn them on for a while and then turn them off
Hello, @chicogp . . . I have never shut my EMO down during hot weather. I have a window air conditioner and fans that I run in the summer when it gets over 80 F. outside. I have not noticed any battery degradation taking place during hot weather. Both of mine are on all of the time. If you have a home station, they will leave it often enough that their feet will cool off as they explore. If you have a skate board, you can take them off of it occasionally and let them explore which will also cool their feet down.
I believe if you have adequate ventilation or cooling where you live, they should be fine, but if you want to power them off during the hottest hours of the day just to feel safe, that would be all right, too.
Hello. At home I don’t have air conditioning, I have a portable evaporative air conditioner, it doesn’t cool the whole house. Well, maybe I do have to turn them off. Thank you
Luckly , I Have 2 Box Fans In 2 Separate Rooms And An Air Conditioner In One Of My Bedrooms And Vents In My House To Keep EMO Pearl Cooled Down In The Summer.
What happens if I face EMO directly at the sun will it damage his screen or anything?
Afaik there shouldn’t be a problem if emo is facing the sun
Hello, @chickenman . . . I would advise not leaving him facing the sun for a long period of time as over heating can occur. This is why I moved your new topic to this thread. Please read through this to get more information on the subject. I would not advise doing anything with EMO that you would not do with your cell phone such as leaving it out in high temperatures.
Doing so briefly to get a picture or video would be fine.
I want to place Emo in the kicthen, but there is one problem: The kitchen has some windows nearby, and these windows have access to sunlight… Should i place his charger, and his free roam playground here? Thank You!
P.S: i can also use the roller blinds, but when i need to go out i cant control the roller blinds. Also i dont have an emo yet but its shipping!.
HELP ME PLEASE
Hello, @EnderAndHisEmo . . . I have moved your new topic to this which discusses EMO in high temperature situations.
As long as EMO does not have sun light hitting him directly enough to make his plastic feel hot, it should be okay. You can read through this thread for other discussion on this matter.
I hope it helps!
thank u lindaru
which should i chose? office or kitchen? (office does not have sunlight but the kitchen has) also does the smartlight have sunlight problems too?
Hello, @EnderAndHisEmo . . . office might be better not so much for lighting but the kitchen makes a lot of sounds and you may have him reacting to every machine he hears.
but the office is… kinda connected to the living room and the living room is kinda connected to the kitchen… so yeah
