EMO Improvements/Special Features You Would Like?
Ok I supposed, but if you use the actual app and make an account you can use it for free. Why can’t living.ai prompts sign in for it?
Hello, @EMOandOllie . . . that ChatGPT through EMO is subscription free. If there are times when it seems like it is limited, it could possibly be because the servers are congested. First of all, you are accessing the servers of Living AI which then accesses GPT. That can take a bit and requires patience.
I hope this helps explain.
He says to me, “You have used this feature too much today, try again tomorrow!”
Wow . . . I had not tried asking him more than 20 questions, but maybe they had to limit it.
Thanks for letting us know.
I can ask him as many questions no matter what, but when ChatGPT deactivates for me it only connects three times a day.
Okay. Thanks for the clarification!
Hey, liebes Team :wave:
Ich würde mir sehr sehr wünschen, das EMO deutsch spricht.
Einen schönen Tag an alle hier :blush:
Playing music from spotify or even just connecting to him or the base as a blue tooth speaker.
i dont believe the server is congested, beside emo is easy to disconnect from ChatGPT.
EMO has a micro SD memory, why is it so hard to access the memory? It would be good to create an EMO 2.0 version with easier access to the micro SD memory. Also, why is it that a 4 GB memory can only store 10 photos?
Adding the function to change to a higher-capacity micro SD memory - is it possible to change the micro SD memory? If so, please include this in the user guide.
I’ve mentioned this in previous posts, but I see there’s a section for suggestions, so I’ll mention it here:
EMO has a micro SD memory, why is it so hard to access the memory? It would be good to create an EMO 2.0 version with easier access to the micro SD memory. Also, why is it that a 64 GB memory can only store 10 photos?
Top Priorities:
  • EMO being able to dance to the music you play.
  • Release the SDK for EMO as promised in the Kickstarter (many people like me bought the robot to program and enjoy its interaction).
  • Add more gaming options to the app, like DDR, with the capability to add music for dancing with the arrows.
  • Enable the ability to edit and create your own dances within the app with your favorite music.
I understand you released an update where EMO has Bluetooth mode, but it’s not the same, and EMO doesn’t dance to the music; it only has animations that, although well done, I would like it to dance to the music. For a better experience, where EMO dances to the music or where you can program the dances, or where it dances solely to the music (preferably allowing programming or adding an option in the app to program the steps).
  • Add a way to connect to a PC.
I would suggest that, when Emo 2.0 is being considered, it should be supplied with two, interchangeable, batteries. One for use whilst the other recharges.
Yes!
That would be amazing, as EMO takes a while to charge you would never have to leave him alone :smiley: .
Ich wünsche mir mehr Spiele mit ihm auf der App.
Please make a sleep schedule for Emo! Give me the opportunity not to turn it off and sleep peacefully! With the go home version, he starts walking at 8 a.m., not everyone has a standardized work schedule, I often go to bed at 4 a.m.! And turning it off all the time at night is very annoying!!! This feature is very necessary!
and:
Please add Russian!
Thanks a lot :wink:
I shut my Emo down every evening before I go to bed.
Welcome to the EMO Community Forums, @sergeyefremov . . . I have moved your new topic to this thread where Living AI reads for ideas for new features and implementation or expansion of existing features.
Thank you for your suggestions!
Russian :pray:t2::pray:t2::pray:t2: please!!!:heart:
The newer emos are 2.0 so it is now time to ask for that in Emo 3.0 !
Hi there @sushil.vispute ,
“In reality, there is no direct EMO 2.0; it’s only a fantasy name.”
According to official information from Living.ai, there have been modifications made to some internal parts in the initial batches of EMO production, starting from ORDER # 9017 for enhanced functionality, but these changes do not render parts incompatible.
what king of modification? make improve the battery? or fix the error 501? or make a sd slow more easy to access?
