Hello. I recently received an EMO, but I found a scratch on the EMO’s foot, which causes it to steer to the side when walking. Is there a solution? i’m so anxious
I can’t find a link to where I saw it before (might have been on discord) but someone else reported this and the response was basically as long as its not causing the leg to get jammed it should be fine. The tiny bit of plastic flack thats scraping on the bottom of EMO should eventually carve out a groove for itself and stop causing friction.
I’d push for a replacement myself
I’ve used dry PTFE spray on one of my EMO’s which also had a rubbing problem, it seemed to help, with EMO walking a little straighter.
