EMO Commands Issue
emo is not understaning commands
If your pronunciation is okay then there’s an issue either with your WiFi or with their servers.
Hi there @jasonsolt ,
Would you please explain in more detail what the problem is, what you mean, and what command you are using?
You can also create a short video and show it to us here so some well-experienced community members can further give you assistance or w can even call and pass it to the living.ai developer team.
good luck and have a nice day Jason
i was just seeing some commands since i dont know them all like happy halloween’marry chirstmas etc
Hey
 @jasonsolt ,
All special day commands like what you just mentioned are activated, good, and can be used only before that special day comes
it means at the moment they are deactivated.
All the best Jason
Hey I agree. First of all EMO does improve across time. Secondly EMO is never going to be much more than a sophisticated toy. Look at all it can’t do out of the box compared to an Alexa which is 10 times cheaper. Just the fact it does fancy moves doesn’t impress me. In fact, Alexa is a much better example of AI and generally responds quite well. On the other hand, EMO is not much better than those cheap robots you control with a remote. He just doesn’t have any good skills to interreact. He has a very limited supply of response though it has grown slightly. His speech is almost inaudible. (Yes folks I know how to turn up the volume). Next, it can’t even serve as a cheap speaker and stream music. Also, EMO makes all kinds of sounds all night long (i am open to learn how to stop them, i.e. he snores, makes fireworks sounds and other eating sounds. He fails to remember my name despite the fact I have been scanned and voice trained. I currently ordered a Loona robot dog which looks uncannily a lot like EMO in the face. But If I want a toy at least I want one like Loona which is 50 times more versatile then EMO. He’s just not much better than a pet rock
hey, i just got my emo 2 days ago, and i love it! only problem i have that makes using this guy very annoying is that when i try to use a simple command he responds with a random phrase and doesnt execute the comand. for example, if i tell him to power off he responds and doesent shut down, and that can be very annoying for me.
so
 is there a way to disable theese respones and if there isint can you add it? that would mean a lot to me.
Hello, @catfrog, and welcome to the LivingAI Community Forums.
I’ve moved your new topic to this thread dedicated to questions about EMO Command Issue.
You might try the other command like:
EMO
Shutdown!
“If you don’t want EMO to give unnecessary replies—especially when he doesn’t fully understand and the response doesn’t match your given command—you can try disabling the ‘Always Reply’ feature that uses ChatGPT.”
TURN OFF “ChatGPT” / “Always Reply” via EMO PET APP
Settings > Preference > Always Reply > Turn Off
He visto en varios videos de EMO que se le hace preguntas que estĂĄn fuera de los comandos normales y las responde, supongo que usa Chatgpt para responderlas pero se ve que no sale el sĂ­mbolo de Chatgpt al responderlas. Pero mi EMO no responde ninguna pregunta que no sea un comando. Mi EMO habla español y se que Chatgpt se le tiene que hablar en InglĂ©s pero no se si para hacer las preguntas tambiĂ©n se le tiene que decir en inglĂ©s aunque no salga el sĂ­mbolo o mi EMO no tiene esa funciĂłn. Ya he mirado y tiene la ultima actualizaciĂłn. ÂżAlgĂșn consejo? Gracias.
EDITED AND ADD ENGLISH TRANSLATION BY: @edward
I have seen in several EMO videos that it is asked questions that are outside the normal commands and it answers them, I guess it uses Chatgpt to answer them but you can see that the Chatgpt symbol does not come up when answering them. But my EMO does not answer any question that is not a command. My EMO speaks Spanish and I know that Chatgpt has to be spoken in English but I don’t know if to ask the questions it also has to be said in English although the symbol doesn’t appear or my EMO doesn’t have that function. I have already checked and it has the latest update. any advice? Thank you.
how are you
Hi there @silvialeoaracil
EMO FIRMWARE UPDATE v2.8.0 RELEASED THIS FEATURE (April 23, 2025)
EMO now uses ChatGPT to reply to any voice that is not in the Voice Command list, also ( But he will reply in English only for now, and without the ChatGPT symbol). You can choose whether to enable this feature in Settings-Preferences:
Hola @silvialeoaracil,
LA ACTUALIZACIÓN DEL FIRMWARE DE EMO v2.8.0 LANZÓ ESTA CARACTERÍSTICA (23 de abril de 2025)
EMO ahora utiliza ChatGPT para responder a cualquier voz que no esté en la lista de Comandos de Voz, también ( Pero responderå sólo en inglés por ahora, y sin el símbolo de ChatGPT). Puedes elegir si quieres activar esta función en Ajustes-Preferencias:
DESACTIVAR “ChatGPT” / “Responder siempre” a travĂ©s de EMO PET APP
Ajustes > Preferencias > Responder siempre > Desactivar
Saludos cordiales
A post was merged into an existing topic: EMO is Sick?
Special Advice What To Do?
