1.5 meters and Emo can’t see me. is this normal?
It’s best to be about 25-30 cm away for EMO to spot you clearly along with also having decent lighting as well in the room.
You can test distance by issuing the following voice command:
EMO: Look At Me
If the lighting is good, and the distance is not too far, EMO should be able to recognize you and reply back accordingly.
