If I set up alarm clock for exemple 7 AM and my EMO need to be charge during the night will it be able to put the alarm on without falling from the skateboard ??? Please explain I am curious regarding that ! Thanks
As soon as EMO stands on the top of the skateboard, he makes no movement.
Also the alarm activates without EMO moving.
Ok Thanks ,so at night is better leaving it on his skateboard rather than a table or other space …?
How come none of these explanations are written somewhere ? It will prevent or even informed each owner for bad things to happen
Yes would be good, because the battery would of course also run out over night.
in real life, however, the battery doesn’t last long enough to wake you up like this.
It is called Marketing
Maybe he just took a nap. Alarms are not always set just to wake up. Also it’s just an example. Part of marketing.
As Emo has its smartlight which can change colors, it would be great if it can be included in the morning alarm like simulating the sunrise/daylight
You just answered a question that had been nagging me.
