Hello friends! I just wan’t to say, if you are here before buying an EMO, that the standard charger might not be fitted for your region. I had to buy an converter in order to charge my emo. Just a headsup!
Thanks for sharing this @Ginos ![]()
EMO owners have discussed/shared this here on the forum on a number of different threads in the past.
Be sure to use the search feature on the forum to look for past discussions, it is very useful and can also be very helpful in looking for solutions and tips if you need help with your EMO.
I’ll go ahead and close this thread. Thanks once again for sharing the info on the charger ![]()
