Hi, I live in apartment and I can not connect the public WIFI because it require typing username(room number) and password via the popup.
Below is the popup that I have to input both username and password in order to use WIFI. Normally, this popup will be displayed after I select the WIFI but on EMO application, it shows nothing
Tagging @Tony for further support regarding this. Not sure if it will work, but Tony will be able to confirm/advise further.
NOTE
EMO can only connect to 2.4ghz WiFi networks . EMO cannot connect to a 5ghz WiFi network frequency and can only support 2.4ghz network frequency due to the WLAN chip in EMO.
Try and find out if what kind of frequency they are using. Also if the WIFI signal is weak, you might also have problems connecting in.
I was using my emo with My 5G network for a long time since I bought it. He was working fine until he updated itself and now is not working anymore!! How the heck he was working with 5G mind blowing!!! Now he stop connecting to my wifi
It’s insane like I didn’t know emo didn’t work with 5G. I was able to connected it with my wifi and it worked fine for the last three months. Thank you for the information I will see how I can connected to my phone. I feel sad I wish I could had taken a video when he was connected with 5g. Hopefully LivingAi can update EMO soon to the latest networks!
Hi, Jackie . . . I think I see what is going on here. Your phone (the cell tower) is on 5-G (as opposed to 4-LTE like mine or the old 3-G), but that is just for running the phone itself, your mobile data when not connected to wi fi. Your internet wi fi router has two choices, 2.4 GHz or 5 GHz. Two different things. You might want to see what your internet wi fi router/modem is set for as it could have changed. Mine has the setting for either or. The router that EMO is connected to has to be 2.4 GHz.
I just discovered what happened my router for some weird reason stop sending the 2.4Gh signal so I called the company to resolve this mystery thinking my emo evolved like Pokémon hahahah and was using 5G. The internet service fixed the problem and now I have both signals again This time now it shows the 2.4gh. I’m so happy to see my EMO working again!
