Hi, everyone,
I ordered my EMO two days ago.
I am now wondering whether I can use the Smartlight in a German power socket without any problems or do I have to buy an adapter for it?
Hi, everyone,
You have to use an adapter .
For the light you only need to adapt the pins for the power outlet, so just a cheap plug adapter will work. The light is dual voltage so does not need to be converted.
For EMO himself you can also use a plug adapter since it too is dual voltage. Of if you already have your own 5 Watt USB-C power supply with the correct plug, then you can just plug EMO’s surfboard cable into that.
To be clear… If you decided to just use your own USB-C power supply to charge EMO, it would need to have it’s own cable. The cable on EMO’s USB power supply is not removable and only unplugs at the skateboard itself.
Ok, thanks for your help
