Me mudé a otra dirección y no e podido cambiarla en mi perfil, me podrían ayudar en eso?
To change your shipping address you need to email: service@living.ai
I’m also tagging @AmyLU , I believe she is one of the order processing people who can help you with that?
Envía los mensajes en inglés. Puedes utilizar el traductor de google.
Si no, corres el riesgo de que ignoren tu mensaje. ![]()
As @macfixer01 mentioned, send the support team an email. The best way to do it in this case is to simply reply to your confirmation email when you made your order. This way when you reply, the support team will have all your details and order number, and they should be able to easily change your delivery address for you.
Best of luck with it.
Hi. Don’t worry. You can send your new address to our customer service team email (service@living.ai) and they will modify the address for you.
