Battery life question!
Hi guys! I have a question for Emo! Sorry for my bad english-. Can i turn off my emo if the battery Is full charged or can I risk something? For example, with smartphone in the future you Will broke battery, but I don’t know if Is the same way with our little friend!
You can tell emo to power down, even if his battery is full. Hope that answers your question!
You can certainly turn your EMO off if it’s battery levels are fully charged. Then when you want to turn him back on, just place him back on the skateboard.
You can check the battery level by asking the following command:
EMO: Show Me Battery
I’m not sure how bad it is to keep EMO always on the skateboard and charging, it’s probably the same with every device, over time the battery will always degrade.
