[AIBI UPDATE 1.1.0] Connection with ChatGPT
Dear AIBI owners,
We have released Update 1.1.0 for AIBI, which includes some new content and many fixes.
How to update
  1. You can update AIBI with the app. Go to Settings - Updates, and click the “Start Update” button if there is an available update.
  2. You can also use voice command “start update”.
Update contents
  1. You can now ask AIBI to connect with ChatGPT and then ask him questions. The startup voice command is “connect to ChatGPT” or “connect to OpenAI”. (Only English for now).
  2. Now when AIBI is not connected to the network, he will start offline voice command recognition (English only). In offline mode, he will use a blue light as a prompt (green in online mode);
  3. Now the charging base lights up when AIBI dances;
  4. With the latest app, you can check AIBI’s battery level;
  5. Fixes and changes:
  • Fixed the problem of incorrect time display in some cases;
  • Fixed the problem that coins were not saved in some cases, and the problem that steps converted to coins were displayed incorrectly after restart;
  • Fixed the issue that sometimes you can lend money to buy food;
  • Fixed the issue that two AIBIs sometimes couldn’t connect or comminicate;
  • Fixed the issue that AIBI not correctly showing full battery;
  • Fixed the issue that AIBI not shutting down properly when low on battery;
  • Fixed the problem of not detecting AIBI’s head being held;
  • Fixed the problem that the language setting did not work in some cases;
  • Fixed the problem of incorrect birthday, zodiac sign, favorite color and lucky number display in the App;
  • Fixed the problem that deleted alarms may still work in some cases and changed the alarm from only working once to working every day;
  • Reduced the cooldown time of teasing AIBI (double-clicking the head), and continuous teasing is now easier to trigger the electric ball;
  • Reduced the proportion of AIBI spontaneously playing funny animations, but you can still let AIBI play them by one tap on his head or through the App;
  • AIBI now responds to being called by name when the app is in settings;
  • Added AIBI’s response to the voice commands “go to sleep” and “be quiet”;
  • Fixed the issue that AIBI sometimes cannot display photos;
  • Fixed the issue that AIBI sometimes cannot shut down correctly and directly cuts off the power;
  • Fixed the issue that sometimes the 12-hour setting does not work correctly;
If you have any issues, feel free to comment. We will also bring more updates:)
:aibi_heart_emoji: YAY!
Once again, many thanks to the Living.Ai Staff and Alpha Testers for their tireless work, bug fixes, and the quick release of this new update.
All The Best!
:aibi_wink_emoji:
Anyone else beside me that has their emo constantly respond saying they can’t respond right now because too many people are using ChatGPT? Is there something wrong with the server?
Hello, @xsakura4ux . . . I have moved your new topic here.
There are many people, myself included, experiencing this issue today. I have a message in to the developers to see if it is internal or something going on with OpenAI.
Hello, @xsakura4ux . . . test again. It seems to be working again.
