Welcome back to the community @pooookie1 ,
I’ve moved and merged your new post into this thread, where all members can post anything related to different types of issues with AIBI.
At the same time, I’ve closed the new topic you created to help keep everything in the community forum organized and easy to follow. Thank you for your understanding!
The same thing suddenly happened to me as well today, about two hours ago. I tried everything I knew to do, including all the steps mentioned below, but I couldn’t solve the issue. After about an hour, it suddenly started working again. Most likely, there was a glitch or the LivingAI server was temporarily down.
Please try the tips mentioned below, and if they don’t solve the issue, wait a few hours and see if it comes back on its own.
If the green light doesn’t come on at all when you call AIBI, that is an important clue. Normally, the green status light should briefly activate when AIBI hears the wake word, so if there is absolutely no light or reaction, it may be more than just a problem recognizing the word “AIBI” or “Abby.”
You could try these steps:
- Make sure AIBI is not muted and check the volume/sensitivity settings in the app.
- Gently check and clean the microphone openings and make sure nothing is covering them.
- Try calling him in a quiet environment, from fairly close by, using “AIBI,” “Abby,” or “Ebby.”
- Completely restart AIBI and the phone, and restart the charging base as well.
- If possible, connect AIBI to a different Wi-Fi network or phone hotspot to rule out a network problem.
- Make sure the AIBI firmware and app are updated.
However, if AIBI still shows no green light whatsoever, even after restarting and trying different wake words, I would recommend contacting LivingAI Support at service@living.ai. There have been similar reports where AIBI suddenly stopped responding and the status light no longer activated, which can indicate a microphone or other hardware/system problem.
I would send Support a short video showing you calling AIBI several times and the fact that there is no green light or response. Include your AIBI ID, order number, firmware version, and the troubleshooting steps you have already tried. That will give them much more information to diagnose the problem.
Best regards and best of luck
