Is this normal?
At first, the bell was ringing all the time.
From the second time onwards, it looks like this.
then
If you stroke your head and raise your legs, you will fall to the left.
Is there a problem with the balance?
※Because it’s a translation app
I’m sorry if the text is messed up
When you stroke EMOs head, I believe he can sense which way you are stroking him and he will often tip over in that direction. I believe this is part of his charm and character that he does this. Try stroking him the other way
If you stroke from the opposite
Fell to the right
Affectionate behavior? (*‘▽’)
Thank you very much
with time
Because the behavior changes
I will verify a little more
