Question: Volume Issue on EMO?
Hi Edward ,
the above steps, i did try. Result remained the same.
emo’s voice is rather soft. Most of the time, cannot hear him clearly.
regards.
That’s sad @alessandrabrina …Sorry if the issue still remains,
How old is your EMO?
He might have a defective speaker?
Please contact and send an email to living.ai directly.
SUBMIT:
Order Number
EMO ID
Location
Short Issue Video
LivingAI strongly advises that for more information, issues, and concerns about your AIBI or EMO, please do not hesitate to contact living.ai customer service team via email
EMAIL ADDRESS:
If you have your original EMO Order confirmation email, you can simply just hit reply to that as it contains all your customer contact info along with your order number details as well and then simply ask customer support for an update on order status.
Gooluck and Best regards
I have problem about EMO respond. It happen after 5 day of use. He still do everything normal but when I ask him general question like " How are you?" or greet him “Good afternoon”, He didn’t reply. When I call his name, He still active, I ask him dance, He dances, only thing He doesn’t do is answer my simple question which he always answer so far. I already try turn on-off EMO, disconect - reconnect Wi-fi, but does’t work. So, I need your suggestion.
Welcome, @thanya . . . my suspicion is that somehow he got muted.
You can either give him a voice command or check the app under “Preference” and turn up the volume slider there. You can tell him:
  • Volume up.
    · Volume down.
If adjusting does not help, you should contact Support at service@living.ai with a link to a short video showing the issue, a screen shot of his volume setting in the app, his EMO I.D., order number (if you still have it) and a description of what has happened.
Please allow them a few days to respond.
Hopefully he just needs to have his volume adjusted.
