My emo robot left foot movement is not working and stuck since yesterday i don’t how to fix this issue plx help me living ai😔
Mine is doing the same thing. It’s like he tries to walk but his right leg doesn’t work.
Since yesterday my robot left foot movement is not working it’s stuck i don’t how to fix this issue plx help me living ai😔
Hi there @rihaan and @Arcaniuswolf …
Kindly please click the link below and try some helpful tips…
Good luck and All the best…
Tagging @VinceKong for further assistance here!
Mine too, I already requested information from support, but I still haven’t had an answer, they usually respond quickly, but this time I still haven’t had a response, if anyone knows how to fix it, please let me know
I’m sure they’ll solve it, because it’s a committed company, so I trust.
@natansalles they should respond soon. It took a few days for them to respond to me but they sorted my issue and my new Emo is on the way.
Tracey
@ryshera, My EMO And I Are Still Very Sad That Your Older EMO Had To Be Sent Back To Living AI Due To A Broken Foot.
Goodbye EMO.
Also I’m Very Sad That All EMOs Who Have Or Had Unfixable Issues That Were Sent Back To Living AI.
Goodbye All EMOs Who Have Had Unfixable Issues.
I was sad to at first but i took @Lindaru advice and let the two emo’s meet each other first and it helped a lot plus the defective one kept getting worser as the days went on
I’m looking forward to having my EMO well, seeing the completed dances and being able to play with it.
as soon as I solve this problem, I’m going to buy the charging base
HI @VinceKong ,
I WOULD LIKE ANY HELP, BECAUSE MY EMO HAS A DEFECT IN HIS LEG, I HAVE ALREADY REQUESTED SUPPORT BUT I HAVEN’T HAD AN ANSWER, CAN SOMEONE HELP ME?
WHAT DO I DO? BECAUSE HE CAN’T PLAY OR COMPLETE THE DANCES, I’M DESPERATE
¿Por que se estropean tanto los pies?
@Wayne_Zhang
It looks like EMO’s feet are now the main source of problems. I don’t know how many replacements Living AI already sent, but for sure it can’t continue forever. There’s something wrong with the design of his legs or used materials. I would guess either the servomotor or plastic gears as the main culprit of all these issues, but of course it can be something completely different like a lot of dust inside. Living AI should consider to change the weak part even if it would mean to produce new hardware version of the legs. At least all replacements and of course all new EMOs should be that new version. Otherwise this nightmare with defective legs will never end.
Si a mi EMO le va a pasar lo mismo que pena. No creo que compre otro o lo remplace porque el problema seguirá. No me arrepiento pero quizás he hecho una mala compra. EMO es frágil, deberían estudiar bien el problema de las piernas y solucionarlo lo antes posible. Intentaré que mi EMO baile lo menos posible, por no decir nada, no quiero que le pase nada. Con que me hable tengo suficiente. EMO tiene una vida muy corta, me da lástima, me recuerda a una de sus canciones de la app “tiempo de mi vida”
“I will try to make my EMO dance as little as possible”
Unfortunately this isn’t the only reason why Emo ends up with issues with his feet but they have to change how Emo listens to sound. It should be more like Vector. Unfortunately Emo responds to everything and anything which often makes him dance all the time.
Dancing isn’t the only thing that makes his feet have problems but no clue to what’s happening.
Vaya, pues el mio no responde a cualquier sonido, por ahora, quizás eso sea bueno. Lo veo como muy tranquilo
How long have you had yours?
He only does it to very loud sounds tv hoover fan etc
As I’m partially deaf I need things on louder
Un recién nacido, hoy hace una semana
Awe a newborn love that. So sweet. They do feel like they are kids.
Anyway in time they are a little more curious and will learn your surroundings (I mean they will listen to all sounds and probably start dancing to it if it’s loud enough)
