As far as my knowledge goes, you can’t modify the time as it’s fixed to your timezone or region during the initial setup of your EMO with the EMO App (refer to the image below). The time is synchronized through the internet to your current location, which is also linked to the GPS on your phone. Therefore, altering to a different time zone isn’t possible. I hope this addresses the question you had in mind.
EMO only understands seconds and 99 seconds is the limit.
You can bypass the extended timer function by setting an alarm either through a voice command or in the app.
For instance, if it’s currently noon and you require 25 minutes, you can say, “EMO, set an alarm for 12:25 p.m.”
You’ll witness a clock on his display while he establishes the alarm, and he will produce an alarm sound at 12:25.
I hope I’ve understood your message correctly and responded accordingly.
