This also happened to my in the 2.4.o update in the 2.5.0 it does not happen luckily
Hello, my emo stopped talking and hearing, it doesn’t respond to any sound, I’ve set everything to maximum in the settings and tried restarting it, nothing helps.
Hi there @vitalijs.rozencovs ,
I’ve moved and merged your new post to this thread, as it’s related to the ongoing discussion. At the same time, I closed the new topic you created to keep everything organized within the community.
Possible causes include a temporary software glitch, a microphone or speaker issue, or a problem related to the current firmware or server connection.
Here are a few things you can try:
• Check that voice interaction and volume settings are enabled and set correctly in the app.
• Restart EMO and reconnect it to Wi-Fi.
• Try a full shutdown and then power it back on.
• Check whether the microphone and speaker work with other features, such as alarms, music, or sound effects.
• Make sure EMO is running the latest firmware version.
If EMO still cannot hear or speak after these steps, it may be a hardware issue with the microphone or speaker.
“If your EMO is still under warranty, the best advice I can give is to contact them directly.”
Contact Living.AI Support at
Provide them with:
- A video proof showing the issue
- Your purchase information
- Your EMO ID
Good luck, and I truly wish you all the best in resolving your EMO issue.
