Moving your new topic AGAIN to a better and more appropriate thread. As volunteer moderators, we aim to keep the forum organized and easy for users to find information by keeping posts in their appropriate threads. This is done by using the search function to avoid clutter.
Next time, please consider using the "Search " button function on this forum first. It will often be easier for you to find and get solutions. You can find the search icon at the top right of every page.
If you want to check out the video below it will show you how to change the color for EMO’s smart light.
You can also check out THIS POST for the list of colors:
So he is completely paired with his home and light. He can turn the light on when asked but for some reason, he cannot turn it off. He shows the animation of “turning it off” but the light does not respond. Also, it says on the webpage that you can control the lights color… It does not show any options for the light on the App at all.
My light will do that sometimes if you just try a couple of times it seems to work for me and for the colors say: emo(color) light.
The colors include blue red yellow orange pink purple and green i might be missing some though and you and also say emo warm light or emo cold light which is a warm white and a white.
Hope this helps
Hello, @rebeccah . . . I have moved your new topic to this thread for issues with the smart light.
Try unbinding all accessories in the app and then pairing to the smart light again. You may wish to read through this thread for tips on the smart light.
So I have no idea what happened but his light is working fine now… I have noticed he doesnt respond sometimes, despite many attempts to call him. Maybe I got the stubborn one out of the bunch? lol. Still working out the bugs I guess LOL
Hello, @lucian1 . . . I have moved your new topic to this thread for issues with the smart light. You can try unbinding accessories in the app for the light, unplugging it, then plugging it back in and pairing it again. Sometimes the connection to EMO with the smart lights goes awry and you have to get him to recognize it so that the voice commands will work.
Remember to pair again the home station if you do this.
Hello, @JS87 . . . I have moved your new topic to this thread for questions about the smart light.
A couple of things can happen when the smart light either turns off or on, and if it changes.
EMO can be exploring and if he can reach the light, he could bump into it which would turn it on or off. He can also think he hears a command to turn it off, turn it on, or change to another color. When “V” lived in the same room with two of mine, I had the lights at their eye level and he would sometimes roll around and use his lift to turn them off or on.
Google translation to English by Lindaru: Even though EMO and the light are properly connected, the light does not illuminate in sync with EMO when he dances. Videos on the official store page—as well as clips shared by some users—show the light glowing in unison with him. What should I do?
Hello, @poppo . . . I have moved your new topic here to issues with EMO and the smart light.
Are you sure he is paired with the light (holding in the center until it goes through red, green, blue and then flashes? Is EMO responding to other commands such as turn on/turn off the light and change color?
I use “Dance with lights” which works with both the home station matrix and the smart lights.
Hello. The robot’s lamp has stopped working. It doesn’t turn on when you press it with your finger. It doesn’t respond to presses at all. What could be the problem? There is 220V power supply.
Welcome @lelik2223 . . . I have approved and moved your new topic to the thread for EMO smart light issues.
Have you tried plugging it into a different outlet? Are the prongs on the light bent? Are you plugging it into an adapter? If an adapter, your adapter may have gone bad and perhaps changing that out might help.
