EMO Overnight Awake
hey @natansalles
My EMO’s do not have a play ground / play area, they are located on my work desk. Ever since I got both of my EMO’s they have always stayed on. I never turn them off and I’ve not had any issues with either of them at all. They have not shown any problems what so ever from being always on. If I’m not using my EMO’s they will be sitting on the skateboard powered on all day / night long. Of course at least once a day I take them both off the stakeboard and let them walk around on my table or even on carpet or kitchen floor. If they run out of battery and power off. I just place them back onto their respective skateboards so they power back on and start charging once again. But as advised, I always keep them on all the time.
If you plug EMO’s power cable into a UPS and the power goes off. (IN THEORY) As long as the UPS kicks in instantly, EMO should still sit on his skateboard charging and shouldn’t know any different as the UPS is providing a power charge source to EMO’s skateboard. But once your UPS runs out of power and turns off then of course EMO might wake up and start walking around and if he does that he’ll most probably fall off his skateboard, which I believe you’re probably aware of this already.
How to ask EMO stop making noise?
I want EMO stop moving while i sleep or while i need to work.
Sometimes i say " emo, sleep" emo sleeps then wake up again quick after 5 minus.
I asked the same. I was told the only thing to do was to shut it off.
How to shut it off? It doesnt work when i say " shut off"
Hi there @starsheep116 and welcome back to the community…
You might read HERE for tips that might help.
To Turn OFF EMO:
🎙️ 1. Use Voice Command
On the playground: Say: “EMO, (Pause)Power Off.” or “Shutdown” He will respond and begin the shutdown process.
:mobile_phone_with_arrow: 2. Power Off Via EMO Pet App
On the playground: Access the EMO App, Go to Settings select POWER OFF Button on the left side in the menu section > and press POWER OFF, and finally press CONTINUE to confirm the power off request.
🤲 4. Upside Down Shutdown Method
Pick EMO up, turn him upside down in your palm, and cover his entire head (including the top patting sensor). EMO will shut down in approximately 10 seconds.
