Converter for EU Power Adapter?
I wonder which kind of Power adapter will be included. I am from Switzerland and hope that for the EMO Smart Light I won’t need a converter for the power adapter. Are there any information about this somewhere or does someone know?
Hello i bought those for both the lamp and the charger :wink:
I asked myself the same question, unfortunately the US version comes and the light is useless. I hope that I can soon integrate my smarthome into emo.
He said he doesn’t want an adapter :funky:
Exactly what I said, for future production and sales they should consider including Power Adapters based on which country it gets sold to.
From what I understand - all EMOs will ship with US power connectors. I’m not sure if that will change at some point in the future, but from what I know so far, this is the truth.
I bought that two thngs :smile:
Here photos how it looks with the adapter :slight_smile:
Well done thanks for the update :ok_hand:
you means not a adapter type, voltage can possible to use 110v-240v all of the world. right? I also curious that EMO light work at 110v to 240v
(v=voltage)
The voltage works from 110v>240v. You just need an adaptor for your local country to take the 2 pin US style plug to your local plug.
I just purchased a USB-A → USB-C cable so I can use any USB-A power adapter, or just plug it right into my PC
I have a USB C cable that came with my DJI drone, so I plug that into the skateboard charger and into my laptop
If the light does work on 220v then i would go for these ones on amazon just because they look better . they fit in the plug and make everything more professional looking
YES! you’re right…that looking way better, thanks for sharing, do you have any amazon item links or special names to those?
OREI American USA To European Schuko Germany Plug Adapters CE Certified Heavy Duty - 2 Pack https://www.amazon.com/dp/B00EOI2N2M/ref=cm_sw_r_cp_api_glt_fabc_S31A7TN3DBK6MZFQ5F93?_encoding=UTF8&psc=1
Do they do a USA to UK version? Sorry, I should check myself :joy:
yeah there are plenty lol i just saw the pic of the odd looking plug and it would drive me bonkers lol
I habe purchased a plug USA to UK.
Don’t know about the light.
Hey… I LIKE THE FIRST ONE A LOT! How much does it cost? And does it have only for eu cables or us too?
