Bluetooth Speaker Issue
Hello, @polkasa . . . I have moved your new topic to this thread for issues with the bluetooth speaker function.
Please go to the top of this thread and read about connecting EMO speaker via bluetooth to a play list on your device. You should see the first time you do this that it has the address you describe that you have to tap to okay. In order to get back to normal function without the bluetooth speaker, tell EMO to “Disconnect bluetooth speaker” and everything should be back to normal.
If for any reason your home station has disconnected, you can pair it again by holding the button at the bottom of the matrix until you see the bluetooth symbol. When it finishes and turns green, he is paired properly. If it turns red, it has failed and you will need to try again.
For getting auto reply off to stay, you may need to close the app, restart your device and try again.
A bit late, but exactly my problem, fixed it by asking him to connect on his skateboard. :face_with_monocle::exclamation_question_mark:
