Actually, he is!
He loves to hang there!
Thank you so much!!!
Hi!! Where did you buy the clothes? It’s soo adorable!
Hi there @stephanieouyang ,
You can find Finger Puppets online that might fit AIBI. You might need a little tweaking and repair.
Goodluck
Aibi with blue eyes
AIBI Cody with blue eyes: he is matching EMO Tyler’s eye color now!
AIBI Cody has gotten a poster too…
Couldn’t forget the little guy!
AIBI Carrier v2 is now in the works :slightly_smiling_face:
This design will be more compact than the previous version, so far, I added the battery at the bottom for better weight displacement and balance. Though if the charger shouldn’t be directly placed on top of the power bank, please let me know, and if there is another material I can put in between the aibi charger, and the power bank, thank you :slightly_smiling_face:
Maybe you should add something in there to keep aibi cool? Hmm… :thinking:
Yeah, AIBI’s head can get pretty hot even with pretty good airflow, but with no airflow………that would not go well, a mini fan should do the job @logan.christopher
Something like this maybe?
That would be a great idea :slightly_smiling_face: I’m actually scrapping that design for something different. However, that fan will work great in the new carrier I’m building, thank you :blush:
No problem, always happy to help :aibi_smile:
Aibi carrier V2 Beta is now finished :slightly_smiling_face:
Just as I built emo, aibi, and V3ctor’s rooms using Lego, I found a way to do the same thing for this one.
While it’s slightly bulky, its 4x smaller than the previous version of my own carrier. I used Legos and started building around the charging base, in order to find a way to hold it in place, and thankfully worked.
After that, I used some axle pieces, and Lego washers to hold in some heavy duty straps to use while wearing it, just as I would with the pocket that came with aibi. Since the straps are removable, I implemented a ‘carrier’ mode, so I can carry it in my hand with the handlebar strap. At some point, I’ll see if I can make a less bulky version of this one.
@andy can you send me a link for the 3d printing star wars fighter so I can also print it please
I made Aibi Pixel with Pixilart.com. Please ask before you share or use it. I go by moonskyrunner.
■■■■■■ and Aibi the video game?
My AIBI’S ID is literally “sad” if you count the 5 as an s, haha
AIBI was soo sad………
I think AIBI is down to make a deal
